Using a Cisco PSTNM Gateway....
mjwilson0675
calls coming in from my cisco gateway are getting these errors....
I found where need to put the inbound pramaters.. I just cant figure out what to put in there...
I would like to some place a rule that "all calls" from the gateway ( @10.101.21.1:5060 as seen below) will be accepted, but again I cant find the right combonation for the rule... can anyone point me in the right direction?
Code:
14:42:00.281  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
  INVITE sip:[email protected]:5060 SIP/2.0
  Via: SIP/2.0/TCP 10.101.21.1:5060;branch=z9hG4bK42169D
  Max-Forwards: 69
  Contact: <sip:[email protected]:5060;transport=tcp>
  To: <sip:[email protected]>
  Call-ID: [email protected]
  CSeq: 101 INVITE
  Expires: 180
  Min-SE: 1800
  Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
  Date: Mon, 05 Apr 2010 18:41:28 GMT
  Supported: 100rel, timer, resource-priority, replaces, sdp-anat
  Timestamp: 1270492888
  User-Agent: Cisco-SIPGateway/IOS-12.x
  Allow-Events: telephone-event
  Content-Length: 0
  Remote-Party-ID: <sip:[email protected]>;party=calling;screen=no;privacy=off
  Cisco-Guid: 2923342421-1075384799-2237585480-3304152238
14:42:00.281  [CM302001]: Authorization system can not identify source of: SipReq:  INVITE [email protected]:5060 tid=42169D cseq=INVITE [email protected]:5060 / 101 from(wire)
You would need to create a DID (number that's being called under) the inbound rules. The you can froward the call to whatever extension you need it to go to. Can you post your current inbound rules.
Get 3CX - Absolutely Free!
3CX
