Using a Phone on an External Network
Discussion in '3CX Phone System - General' started by jensenpos, Jan 8, 2016.
  1. jensenpos
    Dec 31, 2015
    5
    I have a phone handset which I have taken to a remote location, not connected at all to our office where 3CX is running.
    I have the 3CX app running externally with no issues, however when I take one of our physical handsets to a remote location, I can make and receive calls, but get no audio. Below is the log file of the event of an outbound call from an extension at the remote site to an extension in the office where the PBX is... I can see what the problem is, with regards to the IP address of SIP and RTP being different, but I am not sure how to overcome it.
    Help would be greatly appreciated.
    Nathan
    09-Jan-2016 06:33:03.597 [CM504001]: Endpoint Extn:100: new contact is registered. Contact(s): [sip:100@PUBLIC IP OF REMOTE SITE:39300 / 100]
    09-Jan-2016 06:33:01.663 [CM504002]: Endpoint Extn:100: a contact is unregistered. Contact(s): []
    09-Jan-2016 06:30:56.268 Leg L:75.2[VMail] is terminated: Cause: BYE from PBX
    09-Jan-2016 06:30:56.267 [CM503008]: Call(C:75): Call is terminated
    09-Jan-2016 06:30:56.266 Leg L:75.1[Extn] is terminated: Cause: BYE from "PUBLIC IP OF REMOTE SITE":39300
    09-Jan-2016 06:30:53.652 Currently active calls - 1: [75]
    09-Jan-2016 06:30:51.455 [CM503007]: Call(C:75): VMail:999 has joined, contact <sip:999@127.0.0.1:5483>
    09-Jan-2016 06:30:51.453 [CM503007]: Call(C:75): Extn:100 has joined, contact <sip:100@PUBLIC IP OF REMOTE SITE:39300>
    09-Jan-2016 06:30:51.452 L:75.2[VMail] has joined to L:75.1[Extn]
    09-Jan-2016 06:30:51.451 NAT/ALG check:L:75.2[VMail] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
    09-Jan-2016 06:30:51.300 [CM503025]: Call(C:75): Calling T:VMail:999@[Dev:sip:999@127.0.0.1:5483;rinstance=bc4a7b8e1363726f] for L:75.1[Extn]
    09-Jan-2016 06:30:51.259 [CM503005]: Call(C:75): Forwarding: T:VMail:999@[Dev:sip:999@127.0.0.1:5483;rinstance=bc4a7b8e1363726f]
    09-Jan-2016 06:30:51.259 L:75.1[Extn] forwards call from Extn:102 to VMail:999 based on rule Fwd[Available/NotReg]
    09-Jan-2016 06:30:51.259 L:75.1[Extn] failed to reach Extn:102, reason Not Registered
    09-Jan-2016 06:30:51.259 [CM503017]: Call(C:75): Target is not registered: Extn:102
    09-Jan-2016 06:30:51.257 [CM503001]: Call(C:75): Incoming call from Extn:100 to <sip:102@OFFICE PBX ADDRESS:5060>
    09-Jan-2016 06:30:51.257 NAT/ALG check:L:75.1[Extn] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
    'audio' media IP is not equal to the IP specified in contact header:
    'audio' media IP:192.168.1.23
    Contact IP:pUBLIC IP OF REMOTE SITE
    'audio' media IP is not equal to the SIP packet source(IP:port):
    Received from:pUBLIC IP OF REMOTE SITE
    09-Jan-2016 06:30:51.256 [MS003005] C:75.1: Failed to create Endpoint: (destination=PUBLIC IP OF REMOTE SITE)
    EndPoint: ID=000000C4@127.0.0.1:5482(EXTERNAL)
    LOGID=C:75.1 Status: MSEP_FAILED
    RTP:pBX PUBLIC ADDRESS:9104
    RTCP:pBX PUBLIC ADDRESS:9105
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    NOT SET
    101:telephony-event
    Party ptime:20
    Party RTP:0.0.0.0:0
    Party RTCP:0.0.0.0:0
    Decoders:
    <empty>
    10,744
    281
    It might be one of a number of things.
    Set-up and use of STUN might be necessary, if not already implemented
    Local port assigned to set may be in use, by another SIP device on remote network.
    This would seem to indicate that it may be a problem related to the first..
    3CX may be trying to send the audio packets to the local IP of the set, rather than the public IP + local port
    If you check the 3CX server log just after the set registers, it should show the public IP.
