Using Avaya One-X Agent with 3CX
Discussion in '3CX Phone System - General' started by loiselt1, Dec 6, 2015.
  1. loiselt1
    Dec 6, 2015
    Hi all,
    Just doing some tinkering around in my testbench environment, but I was wondering if the Avaya One-X Agent softphone is compatible with and can be used with the 3CX platform, and if so, how do I configure it so it is able to communicate back and forth?
    Thanks,
    T
    10,366
    227
    A site I came across would seem to indicate that it is using SIP, which means, in theory, it should work. You may, however, have limited functionality and, of course, you would have to manually configure it.
