Using cellular voice rather than voip
Discussion in '3CX Phone System - General' started by Tristram, May 22, 2017.
  1. Tristram
    May 22, 2017
    Hi All,
    We have some mobile users and patchy 3g only coverage wanting to make calls out via their cellular service to the 3cx PBX and receive calls over their normal cellular service with the 3cx client just saying whos calling. Is this possible with 3cx and if so what sort of config would it look like? I've got the extensions calling the mobile however the app isnt showing up who it is or anything
    Cheers
