using DMlink or dialogic products
Discussion in '3CX Phone System - General' started by asfuture, Mar 18, 2008.
  1. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    is anybody there with experince in using products like DMLINK?? take a look on http://www.dmlink.net/products_en_info.asp?proid=601&sorts=DM400A ???
    or from dialogic the DM/IP241
    http://www.dialogic.com/products/ip_enabled/DMIP_DM3.htm
    this wil simplified the infrastructure from a network...
