Using E1/T1 PCI-express card
Discussion in '3CX Phone System - General' started by tarzem, Nov 8, 2007.
  1. tarzem
    Nov 8, 2007
    I've a Quad E1/T1 board installed in PCI-Express slot of my PC. Can 3cX support this E1 board to make external call to a GSM operator?
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    As I know 3CX does not supprt PCI boards, so no calls using it
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    We're supporting any PSTN-to-SIP gateways. If your card has drivers that make it PSTN gateway - it will work. Otherwise - no, we do not have direct support of any hardware.
