Using Exchange 2010 public folder as address book on phone
Discussion in '3CX Phone System - General' started by oakley, Aug 21, 2012.
  1. oakley
    Aug 10, 2012
    19
    Is there a way to use an Exchange 2010 public folder that is a company contact folder as an address book on the phone or in MyPhone?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Re: Using Exchange 2010 public folder as address book on pho
    If your phone supports multiple phone books, then you might try to write a script/exe to create an XML file based on the PF and store it on the PBX in a format appropriate for your phone handset.
    Check C:\ProgramData\3CX\Data\Http\Interface\provisioning and look for xml files in this folder that correspond to your phone. Then you will also need to add it to your phones provisioning file.
