Using Keyboard Numbers for Options
Discussion in '3CX Phone System - General' started by jfarmer90, Jan 24, 2017.
  1. jfarmer90
    Aug 16, 2016
    Hi there,
    We are using our phones in CTI mode. Is it possible to be able to use the numbers on the keyboard when being prompted at an options menu? I'm sure we used to be able to but haven't been able to recently, now I'm wondering if I'm going slightly crazy!
    Thanks,
    James
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,448
    541
    Hello @jfarmer90
    I am afraid you can not use your keyboard when using CTI. The keypad on the client will be greyed out so you can only use the phones buttons.
    The keypad is not greyed out however when using the "Make call" function. So maybe that is what you remember.
