using modems as ATAs?
Discussion in '3CX Phone System - General' started by Watashi_FR, Dec 15, 2006.
  1. Watashi_FR
    Dec 5, 2006
    63
    Would it be possible to use voice-enabled modems (such as the Diamond SupraExpress 56i/e) as ATA devices? Either as FSO or FSX or both?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,005
    308
    Modems can not be used
    Hi Watashi,
    No, unfortunately modems can not be used. Its much better to use VOIP gateways. We have succesfully tested with the Grandstream VOIP gateway, which costs $249 for a 4 port model or $395 for an 8 port model. There are also 1 port devices from Sipura at $89. Its much better to use these devices then a modem.
