Using more than one digit with digital reception
Discussion in '3CX Phone System - General' started by SB67, Nov 24, 2008.
  1. SB67
    Sep 24, 2008
    9
    The digital reception gives you the ability to configure only one digit for caller selection.
    This allow you to have only 10 input (without linking to other digital reception menu)
    Question:
    It’s possible to use the digital reception for automatic route the calls to specific extension by pressing more than one digit like:
    “If you know the extension number, please dial it know.
    For ………. Press 101
    For ………. Pres 102
  2. SB67
    Sep 24, 2008
    9
    It's working :D
  3. sharmack
    Oct 7, 2008
    20
    In manual it says that you can type ext number if know to while you are connected to Digital Receptionist
    how ever if I enter ext 1001 or any other one I get
    "An error occured in IVR session sorry"
    and then I get cut off
    Is there something I need to configure somewhere to enable the users to connect to the ext
    instead of waitng for DR to finish message ?
    Cheers
    Shaun
