using multiple IP Phones
Discussion in 'Windows' started by Adler Net, Oct 14, 2016.
  1. Adler Net
    Oct 14, 2016
    When i’m using multiple IP Phones that support CTI.
    i’m getting promoted again and again to choose wich device will be used.
    Is it possible to add an option / maybe it’s already exist to save the settings and not promote this message again?
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    13
    There is no option to do that. Each time you launch the 3CXPhone you have to choose an IP phone
