Using my existing landline (not voip)
Discussion in '3CX Phone System - General' started by Nivleshc, Feb 15, 2011.
  1. Nivleshc
    Feb 15, 2011
    Hi all
    A newbie question. Is it possible to use my existing landline with 3CX so that i can get calls on it an then 3CX will allow me to divert it to an extension? I want to be able to get my existing landline calls diverted to my iphone via internet using the app and i do not want to use a voip gateway (my existing home phone+adsl bundle is quite expensive and has got lots of national calls with it and so i dont want to add more costs by paying for a voip line)
    Looking forward to your help
    Thank you
    Nivlesh
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Yes
    You need a PSTN gateway. See the list of supported gatesways for 3cx at this page. http://www.3cx.com/blog/support/
    The Linksys will probably do fine for your needs.
  3. leejor
    10,586
    252
    If you expect to receive calls on the iPhone then I'm assuming that you will have it registered as a 3CX extension and be using it with your providers dataplan (3G?) or through a WiFi connection.
