Using private SER
Discussion in '3CX Phone System - General' started by drpandol, May 14, 2008.
  1. drpandol
    May 14, 2008
    Hello guys,
    I'm a newbie to 3CX VoIP Client but I'm learning about SIP, SER, and VoIP.
    I configured SER on my workstation and want to test it but I don't know if I can use 3CX Client to do that.
    It seems like it can be only connected to 3CX server.
    Does anyone know if it suuports it or not? If it is, how can I connect to my private SER?
    Thx in advance.
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    It can be connected to any SIP-based server, but definitely you will not receive presence information from servers other than 3CX PBX. But basic softphone functionality will work.
