Using SRV for the sip accounts
Discussion in 'Android' started by sacoo, Aug 19, 2010.
  1. sacoo
    Aug 19, 2010
    I'm a new user of 3cx android client after reading good reviews everywhere. I'm having a problem with my setup tought.
    The same setup is working with sipdroid and linksys SPA941.
    My users are the type: user@domain.com, and all the registration stuff is done by Opensips.
    Following this guide for the spa it works flawlessly using the srv entries for my domain.
    http://forum.voxilla.com/cisco-linksys-sipura-voip-support-forum/configure-spa941-spa942-use-dns-srv-17402.html
    On the sipdroid I am using the domain parameter + proxy and it works too.
    Does any of these two solutions work with 3cx, I've tested all the combinations and I couldn't even register.
    Cheers
