Using the appropriate standard for phone numbers
Discussion in 'Android' started by gauvins, Jul 10, 2010.
  1. gauvins
    Jun 30, 2010
    7
    My contacts numbers are formatted using the + followed by country code followed by the area and local number, as per ITU-T recommendation E.123. AFAIK, this is the only way that will work whenever you travel, as international prefixes are not the same everywhere.
    This is not working with 3CX. (!?)
    sipDroid has a partial fix (search and replace). What could be done with 3CX?
  2. djmills32
    Sep 19, 2010
    I've got the same issue. Did you find a fix or work around for this?
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,580
    115
    This is a feature 3CX does not provide for the moment, though it may be something to be added in the future.
    For now though we do not have such a feature.
