Using VAD 15 with PBX version 14
Discussion in 'Call Flow Designer' started by peppinoa7, Sep 19, 2017.
  1. peppinoa7
    Sep 19, 2017
    11
    Hi!
    Is it possible to use the latest VAD 15 with version below 15?
    I am not managing to find the way to publish the project to the PBX.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
    Hi @peppinoa7,
    No, that's not possible. The new CFD only works with v15.5. You need the old VAD for v14 in that case, which is licensed and has some differences with the new one (you will not be able to open your v15 project with the old VAD).
    Kind regards.
    Ernesto.
  3. peppinoa7
    Sep 19, 2017
    11
    Hi Ernesto,
    Thank you. I upgraded to V 15 all went good but I lost all previous IVR. Or better IVR still exist but all are muted and anfter some seconds I hear Thank you and goodbye and the call hangs.
    Did I miss something?
    Thanks, Giuseppe
  4. edossantos
    Jun 27, 2007
    1,611
    126
    Do you mean IVRs created with the old VAD? You need to migrate the old VAD projects to v15 and then deploy them again. A VAD v14 project can't be migrated to v15 using the backup and restore.
  5. peppinoa7
    Sep 19, 2017
    11
    No, I mean the manually created automated responders deployed on V 14
  6. edossantos
    Jun 27, 2007
    1,611
    126
    Those should work. Please ask that in the general forum.
  7. peppinoa7
    Sep 19, 2017
    11
    I went finally on the version 15 and sorted out with previous settings.
    Now I created a VAD project, followed the procedure. Uploaded the compiled vad file, got confirmation, no error and resterted the services.
    Anyway 3CX looks like not considering the VAD application and the internal ext is working as standard call queue.
    Can you please help?
  8. edossantos
    Jun 27, 2007
    1,611
    126
    What happens when you call the queue extension where you deployed the CFD app? Do you hear any audio? Can you please check the Queue Manager logs to see if you find anything unusual? Please check this guide:
    https://www.3cx.com/docs/manual/cfd-troubleshooting/
  9. peppinoa7
    Sep 19, 2017
    11
    Nothing at all.
    I checked, no building errors, no errors in the 3cx.
    Anyway the extension is behaving like any other queue (music and extensions ringing)
    Just to be sure you understand correctly create a new queue, give name extension and assign members. When you cann you hear the classin 3cx music. This is all what I can see.
    Of course I am uploading the VAP project, double restarting the services but it keeps the same.
  10. edossantos
    Jun 27, 2007
    1,611
    126
