Using VLC to Output Multicast Paging
Discussion in '3CX Phone System - General' started by almityone, Jun 24, 2011.
  1. almityone
    Jun 24, 2011
    I have a current paging setup that accepts an RCA in and wanted to use the sound card as the paging output device for the overhead speakers.
    I tried using the 3cx softphone as a paging device but occasionally it would have issues and give a busy signal.
    I discovered that VLC can accept the multicast paging output as an rtp stream.
    To do this:
    For Example: Setup a multicast page on IP 224.0.1.75 port 50001 (or the settings you prefer)
    Then you can start VLC using the following.
    "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" rtp://224.0.1.75:50001
    OR
    From VLC menu
    Media, Streaming, Network, enter URL rtp://224.0.1.75:50001, Then Select play at bottom
    Hopefully this helps somebody out.
    Matt
  2. almityone
    Jun 24, 2011
    I have further refined this if anyone finds this useful. I am using grandstream phones that do not support multicast and have been having issues with paging.
    Using VLC: you can setup a hidden vlc at startup on your users computer and bypass paging the phones all together.
    Setup multicast at different addresses to acheive different groups and start a vlc (or multiple) on each computer to achieve different multicast paging groups.
    multicast paging: 901 sales team
    start /min "VLCStreamer" "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" -vvv -Ihttp rtp://224.0.1.75:50001
    multicast paging: 902 everybody
    start /min "VLCStreamer" "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" -vvv -Ihttp rtp://224.0.1.75:50002
    Maybe somebody will find this useful
    Matt
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    this is handy... I was just responding to someone having trouble with paging to lots of phones.
    http://www.3cx.com/forums/page-100-phones-34067.html#p148220
    I have yealink t38 with custom firmware with multicast paging... but this is a great idea... i.e., my warehouse.
