using voipcheap?
Discussion in '3CX Phone System - General' started by Aaron, Sep 7, 2007.
  1. Aaron
    Sep 7, 2007
    Does anyone know how to use voipcheap on 3cx? I can make it work directly from a softphone, but not from with the "add voip provider" section
    it just tells me "identification is invalid"
    What do I need to change?
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I use VoIPCheap on 3CX with no issues. Setup was simple using generic template, nothing unusual. I would suggest rechecking ID, Password, SIP and STUN server entries for errors. If a screen print of my setup would help just let me know.
  3. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    If you are receiving such an error it means that proper SIP comunication between your PBX and the provider is in place.
    I would recmend you focus on the line (account) settings of you provider and like Aaron mentioned recheck the ID and password as it is the most likely cause of this failure.
  4. tazz
    tazz New Member
    Sep 12, 2007
    124
    Screen Shot
    Could anyone share with me the screen shots for VOIP Cheap please.
    Thanx
    TAZZ
  5. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
