Using Wireshark in 3CX Linux
Discussion in '3CX Phone System - General' started by datamerge, Dec 6, 2016.
  1. datamerge
    datamerge New Member
    Nov 19, 2014
    176
    22
    Here is a tip to allow easy SIP call tracing directly from Linux without needing to use TShark, or tcpdump to create and export pcap files.
    Install wireshark with apt-get install wireshark. It is a big install, but causes no problems to the PBX.
    Download and install xlaunch onto your own PC. XLaunch is an excellent open source X-Window server for Windows. You get it from Sourceforge.
    Run xlaunch. You will get a wizard.
    Choose multiple Windows, then next.
    Choose start a program, then next.
    In the start program field, type wireshark. Tick using Putty (plink.exe). Enter the IP address of the PBX computer and your login and password. Click next and next again.
    At this point you can save the configuration to a file which you can later double click on to automate the entire process. It is optional. When finished click Finish.
    At this point you should see Wireshark start on your PC as if it was running locally. Now you can do your captures and run all the cool analysis tools built into Wireshark directly on your PC.
    Hope this is helpful to others.
    Linux rocks!
    JCLloyd likes this.
  2. 12494
    12494 Member
    Apr 16, 2010
    298
    29
    Just checking with you - I visited sourceforge but was not able to find something called xlaunch. Can you provide any additional specifics please?
    Thanks.
    Regards,
    Allen
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Maybe we should search for Xming?:cool:
  4. datamerge
    Nov 19, 2014
    176
    22
    Yes sorry. XLaunch is the app you will use, but the project is in fact Xming.
