v 12.5 to v 15 - callhistory table
Discussion in '3CX Phone System - General' started by denn, Mar 19, 2017.
  1. denn
    Dec 5, 2012
    15
    Dear forum,
    I just upgraded our 3CX Phonesystem from 12.5 to version 15. I made a full backup (excluding recordings) on the 12.5 installation.
    I then installed version 15 and restored from the backup. Afterwards I pointed the recordings folder from the default folder (ProgramData/Recordings) to my recording folder (Y:/Recordings). The phonesystem found the recordings and registered them in admin interface.
    My problem is that I have built an integration batch job which moves call history from the postgre database to my MySQL database. To my big surprise I now see that the callhistory table in the postgre database is empty and new calls in v15 isn't logged in that table.
    In which table can I find my call data from before the upgrade - and where is the new stored?
    Is something broken in the upgrade or is this a new behaviour?
    Best regards,
    Denni
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    The call logs in V15 are a different format. After the installation you need to convert the old call logs to the new format. There's a tool that comes with 3cx to do this.
    In my case, it's in c:\program files\3cx phone system\instance1\bin\CHconverter.exe ... run it on the 3cx server, it'll ask you where your backup file is and it will convert the 3cx call history from old version to new version.
    As always, take a backup before running this, just to be safe.
    ... not sure how this will affect your batch job, but this will bring back the call history that was in your 3cx backup.
    #2 JasonNadeau, Mar 19, 2017
  3. denn
    Dec 5, 2012
    15
    Hi Jason,
    Thank you. I just ran the covert tool and it seems to work.
    Do you know which table in the DB that v. 15 will log calls to?
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    No idea, never looked.
    Glad the converting is working though !
