Solved V.15.2.4.122 Broken link/page not found in iOS App link
Discussion in 'iOS' started by dan_tx, Jan 18, 2017.
  1. dan_tx
    Nov 3, 2016
    84
    22
    When you open the app and have the "Phone" or dial pad selected and select the status button (green square top right corner). On the next screen that pulls up that displays the different statuses you can select, if you select the (i) button in the top left corner it takes you to a Page Not found.
    This also occurs when you select the "Recent" tab/butotn on the bottom and select the (i) in the top left corner.
    I'm assuming it should be the same link that the (i) button in the top left corner on the "Presence" tab takes you too.
    Device Info
    Phone Model: iPhone 6s Plus
    Generation: 6s
    Firmware Version: 10.2
    Jailbreak: No
    Cydia Installed: No
    Issue Info
    Handset: Phone
    Contacts: local
    Connection: wifi and 4g
    Server: internal and external
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,960
    180
  3. dan_tx
    Nov 3, 2016
    84
    22
    Well I'm not sure what version your using, in mine the link is still https://www.3cx.com/user-manual/forwarding/ (new link) Which goes to a page not found.
    As mentioned this is if you have the dialpad selected (or "Phone") and select the green box from that screen. Not selecting the (!). Then on the following screen you select the (!) If you have Preseence or COntacts selected and select the (!) from there it takes you to www.3cx.com/user-manual/presence/ which I'm guessing is where you are going unless yours doesn't included the /presence/.
    Photos attached.
    #3 dan_tx, Jan 24, 2017
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    Here too.
    I experience the same problem with v15.2.4.122 too.
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,434
    61
    OK, this is fixed and will be available on the next release.
    Thanks!
    dan_tx likes this.
