V1.0.22 - BT homehub softphone (broadband talk)
Discussion in 'iOS' started by urbanbushcraft, Feb 4, 2011.
  1. urbanbushcraft
    Feb 4, 2011
    Device Info
    Phone Model: iPhone
    Generation: 3GS
    Firmware Version: 4.2.1
    Jailbreak: NO
    Cydia Installed: NO
    Issue Info
    Handset: Phone
    Contacts: Local
    Connection: WiFi
    Server: External
    Hopefully a simple question to get my configuration correctly entered.
    (In case you are not aware BT Boradband talk allows you to use a softphone for your home number, and works in conjunction with an alternative phone number tied to your BT home router (external SIP server).)
    I believe my issue is between my ears - I cant seem to get the correct setting matched to the fields in the 3CX iphone app.
    Here is the info I am basing this on : http://forums.thinkbroadband.com/voip/3699427-using-bt-home-hub-just-as-a-voip-gateway.html
    what I am hoping someone can help with is how this can be matched up to the fields in the settings :
    (here is what I have tried)
    [all other settings are default]
    (the 44*********** is the telephone number with 44 as UK country code)
    I am guessing this is a simple translation issue between BT terminology and 3CX and I would appreciate any pointers please.
    Thanks - David.
  2. StefanW
    Jun 2, 2009
    1,198
    79
    Re: BT homehub softphone (broadband talk)
    I have a small guess.
    Ur Provider needs 2 Proxys which is very rare.
    &SIPOutboundProxyAddress=sip.btsip.bt.net
    &SIPProxyAddress=btsip.bt.com
    As you can see we only have one proxy filed. You may can run a test with our 3CXPhone for Windows (XP Vista 7...) and set it up with this first due to it is the most advanced client we have. If this fails, i dont see much hope for the setup in the 3CXPhone for iPhone
  3. urbanbushcraft
    Feb 4, 2011
    Thanks for your help. after all the fiddling I have done I have not been able to get it to work. According to some other posts I have read BT don't use a 'true' SIP protocol so it may be impossible. I will keep looking for a solution and update if I find something new.
  4. StefanW
    Jun 2, 2009
    1,198
    79
    Here are some native US VoIP Provider for you:
    888 VoIPStore
    BroadVox Fusion
    CallCentric
    Cbeyond
    NextVortex
    SoTel Sip
    They have been tested agains your PBX Solution
  5. gdt
    gdt
    Apr 21, 2011
    Whilst looking at the same thing, I found this page - http://www.btbba.co.uk/BBT_on_Hero.asp - on how to set up BB Broadband Talk for a client called "Sipdroid". Clearly, that doesn't work on an iPhone, but it may be possible to work out the right settings from that page.
    Greg
