V1.0.22 does not run in the background anymore
Discussion in 'iOS' started by daejeon, Feb 3, 2011.
  1. daejeon
    Feb 3, 2011
    Hello guys, V1.0.22 does not run in the background anmore. any solutions?
    Firmware version 4.2.1(8C148) ipod touch
    thanks in adavance
  2. StefanW
    Jun 2, 2009
    1,217
    88
    http://www.3cx.com/forums/3cxphone-for-iphone-change-log-17918.html
    check last post
  3. daejeon
    Feb 3, 2011
    Hello Stefan, It only works for active calls. But I want to run it in the background eventhough there is no active call. I don't want to miss the calls. Any help? Is there anyway to download the older version? Thanks
  4. StefanW
    Jun 2, 2009
    1,217
    88
    we know about this issue and hope to fix it correctly in 1.0.24 based on TCP connection to your PBX or Provider.
    Our implementation before was wrong and bat. draining. so we had to remove it for the moment to get to the source of the issue. well we located it and can work on it now.
