V1.0.23 - Calls over 3G Possible but not over WLAN
Discussion in 'iOS' started by r2k, Mar 14, 2011.
  1. r2k
    r2k
    Jan 9, 2011
    23
    Hi folks,
    i've a strange issue which i do not understand.
    It is possible to make and revice calls over 3G (i can hear and talk to the other person) but not over Wifi.
    Some information:
    Phone Model: iPhone
    Generation: 4G
    Firmware Version: 4.3
    Jailbreak: NO
    Cydia Installed: NO
    I am using the external server by dns (pbx.company.ch) and the 3cx stun server (stun.3cx.com) . The local sip Port on the device is 5060 and the first rtp port is 4000. TCP Transport is disabled but the nat-helper is enabled.
    Now some logs:
    --> I've replaced my public ip with "my-public-ip" and the pbx hostname with pbx.company.ch
    Call over 3G
    This one is working
    Code:
    14:41:40.814  [CM503008]: Call(1152): Call is terminated
    14:41:27.705  [CM503007]: Call(1152): Device joined: sip:999@127.0.0.1:40600;rinstance=db204fe05103f8c8
    14:41:27.705  [CM503007]: Call(1152): Device joined: sip:209@193.247.250.59:59074
    14:41:27.689  [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:999@127.0.0.1:5060]
    14:41:27.689  [CM503002]: Call(1152): Alerting sip:999@127.0.0.1:40600;rinstance=db204fe05103f8c8
    14:41:27.533  [CM503025]: Call(1152): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=db204fe05103f8c8]
    14:41:27.486  [CM503004]: Call(1152): Route 1: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=db204fe05103f8c8]
    14:41:27.486  [CM503010]: Making route(s) to <sip:999@pbx.company.ch>
    14:41:27.470  [CM505001]: Ext.209: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for iPhone 1.0.23] PBX contact: [sip:209@192.168.50.26:5060]
    14:41:27.470  [CM503001]: Call(1152): Incoming call from Ext.209 to <sip:999@pbx.company.ch>
    Call over WIFI
    No Audio between the pbx and the iphone
    Code:
    14:40:48.752  [MS105000] C:1151.1: No RTP packets were received:remoteAddr=my-public-ip:4000,extAddr=0.0.0.0:0,localAddr=192.168.50.26:7318
    14:40:16.408  [CM503008]: Call(1151): Call is terminated
    14:40:16.408  [CM503021]: Call(1151): ACK is not received
    14:39:46.283  Currently active calls - 1: [1151]
    14:39:44.361  [CM503007]: Call(1151): Device joined: sip:999@127.0.0.1:40600;rinstance=db204fe05103f8c8
    14:39:44.361  [CM503007]: Call(1151): Device joined: sip:209@my-public-ip:5060
    14:39:44.345  [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:999@127.0.0.1:5060]
    14:39:44.345  [CM503002]: Call(1151): Alerting sip:999@127.0.0.1:40600;rinstance=db204fe05103f8c8
    14:39:44.205  [CM503025]: Call(1151): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=db204fe05103f8c8]
    14:39:44.142  [CM503004]: Call(1151): Route 1: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=db204fe05103f8c8]
    14:39:44.142  [CM503010]: Making route(s) to <sip:999@pbx.company.ch>
    14:39:44.142  [CM505001]: Ext.209: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for iPhone 1.0.23] PBX contact: [sip:209@192.168.50.26:5060]
    14:39:44.142  [CM503001]: Call(1151): Incoming call from Ext.209 to <sip:999@pbx.company.ch>
    The first three lines are very strange. I am connecting over the same firewall on my workplace. The only different thing is, at home I am using a fritzbox. The funny thing is, it was working some weeks ago...
    Can you help me with this issue?
    Marco
  2. r2k
    r2k
    Jan 9, 2011
    23
    Re: Calls over 3G Possible but not over WLAN
    Hi folks,
    there is an update :)
    i've tried it with another wifi (not at home) and there it is working.
    It looks like a fritzbox issue :(
  3. StefanW
    Jun 2, 2009
    1,199
    79
    Issue is that u put the server always as you would see the server external.
    But in the phone you see 2 fileds.
    Internal Server:
    External Server:
    And an togel Box above them.
    When you are in ur WiFi where als the PBX is disable togel and put the IP of the PBX in the internal server.
    If you on 3G or on ur mates WiFI enable the toggle and put the PUB IP of ur PBX in the external server.
    Tech speaking, in the moment u use the external server the phone goes to the internet and finds out his external ip at the time and uses this to tell the pbx where it is. so if you are internaly and tell the pbx you are external the pbx goes and looks for you external where you are not...
  4. r2k
    r2k
    Jan 9, 2011
    23
    Hi Stefan,
    thanks for your replay.
    The WIFI is at home and the pbx is in my corp lan some miles away.
    I've enabled the "use external server" toggle when I am using my wifi at home. I've enabled the toggle too on my friends wifi. There is no wifi at work, just 3G.
    Best regards
    Marco
  5. StefanW
    Jun 2, 2009
    1,199
    79
    Ohhh fritzBox dont work mate. in a fritz box is an integrated sip server fetching all sip data away for you.
    youc an try to set the sip port in ur phone to a different one then port 5060. in the version 1.0.23 you can change this and may give it another go. but it will be hard....
    what i would do is start a vpn connection from the iphone to the lan and just work with the internal IPs
