V1.0.23 - inter office contacts on iphone
Discussion in 'iOS' started by jonnybluehat, Apr 13, 2011.
  1. jonnybluehat
    Feb 15, 2011
    8
    hi all,
    just installed the iphone app and im looking for a way to add contacts for the inter office.
    ex
    ext 3003
    dialing the ext works fine but when i tried to add new numbers to the iphone contact list it would separate it as 300-3 and instantly hang up on me
    am i missing a button some where ?
  2. StefanW
    Jun 2, 2009
    1,222
    93
    Re: inter office contacts on iphone
    no this does apple based on your country the formating.
    Open the normal apple contact book and you will see the same behaviour.
    issue i dont under stand we strip in the background all () and - in numbers for you.
    can you send me the log from the server activity log in the 3CX it self when u are in verbose logs.
    thx
  3. StefanW
    Jun 2, 2009
    1,222
    93
    i just checked it out with my version (1.0.23 in the app store) and the - was stripped
  4. jonnybluehat
    Feb 15, 2011
    8
    i may not have explained it right
    what im lookin for is to have a contact list for my inter office extensions on 3cx
    if i manually type in the 4 digit extension the phone rings no problem
    if i add 3003 to a users contact and try to dial from there i get a fast busy signal.
    i dont have this problem on the android app just iphone
    its a apple 4 current software build no j/b
  5. StefanW
    Jun 2, 2009
    1,222
    93
    Re: if i add 3003 to a users contact
    Where is that i can not follow you
