v1.1.4 - Impossible dial on iPhone 3GS (iOS v5.0.1 - 9A405)
Discussion in 'iOS' started by jr3151006, Nov 21, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    I updated right now our Sales Man´s iPhone to v1.1.4 and tried to dial to another extensions, it not complete the dial and show 'on hook' again. He also is unable to receive call - he are connected through WIFI.
    Can some one help me on how to debug that??
    * using Cisco Phones (SPA 502G or 504G) or Android phones or Windows softphone we are able to dial fine to any number inclunding other extensions as the '109' (running on my Samsung Galaxy S GT-i9000B).
    * iPhone 3GS (iOS v5.0.1 - 9A405)
    * Jailbreak: NO
    * Cydia Installed: NO
    * Connection: WiFi
    * Server: Internal
  2. jr3151006
    Jul 30, 2010
    155
    Re: v1.1.4 - Impossible dial on iPhone 3GS (iOS v5.0.1 - 9A4
    Just for information, our 3CX server is running v10 spk4.
  3. jr3151006
    Jul 30, 2010
    155
    Another information is that the iPhone do not ring if other extension try dial to it, but it rings when receive external call (received by our gateway).
    * Make no sense...
  4. jr3151006
    Jul 30, 2010
    155
    I´m trying to dial to external number (like my mobile number) and then my mobile ring 1 time only and the call is hanged...
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,527
    71
    "488 Not Acceptable Here; warning: No suitable codec for remote offer"
    You mentioned a gateway... I remember I read a post somewhere here somebody mentioned it had a similar issue and he found that its gateway doesn't support GSM codec - so, in 3cxphone, try to disable GSM codec and on top move the aLaw or uLaw.
  6. StefanW
    Jun 2, 2009
    1,222
    93
    and in addition, user agent not matched is nothing to worry about, this only states that the PBX has not "profile" for this phone to override phone capabilities or not. Due to it is our product we dont need them. So dont worry
  7. jr3151006
    Jul 30, 2010
    155
    Ok Stefan,
    tks for the explanation.
  8. jr3151006
    Jul 30, 2010
    155
    Hi Vali,
    I´ll try to check the option that you adviced.
  9. StefanW
    Jun 2, 2009
    1,222
    93
    @beck, sorry even been german but my dutch is not as good ;-) what you say?
  10. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    Hi Stefan,
    Sorry, but beck1123 is a spammer.
    What he is posting is crap.
    Regards.
  11. StefanW
    Jun 2, 2009
    1,222
    93
    thx for letting me know, removed the post
  12. jr3151006
    Jul 30, 2010
    155
    After set the GSM codec as '0' and reduce its priority, now I´m able to dial from iPhone.
    * only when inside our network - but it´s another problem that I already create a new post in this forum.
    tks
