v1.1.4 not working from outsite network
Discussion in 'iOS' started by jr3151006, Mar 30, 2012.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    I´m able use remotely the 3CX for Android and Windows (both using 3CXTunnel), but not with iPhone. The iPhone only works when inside our network. I tested using Wireless and 3G remotely - at the same time my Android worked fine on both situations.
    >>> There is some log file to check on iPhone?
    >>> Can 3CX provide a new version with 3CXTunnel support?
    >>> Other ideas???
    * iPhone 3GS (iOS v5.0.1 - 9A405)
    * Jailbreak: NO
    * Cydia Installed: NO
    * Connection: WiFi
    * Server: Internal
    10,362
    227
    You don't say who you are trying to use this with , 3CX PBX, VoIP provider?? If it is with 3CX then check the 3CX log, it may show you what the problem is.
    As for the new version with tunnel, it sounds like it is coming.
  3. jr3151006
    Jul 30, 2010
    155
    Hi Leejor,
    we are using 3CX PBX system.
  4. leejor
    10,362
    227
    And.....do you see an attempted registration? Rejection?
    Are you trying to register to a Domain name (3CX location)?
  5. jr3151006
    Jul 30, 2010
    155
    Hi Leejor,
    I dont understand your msg: "Are you trying to register to a Domain name (3CX location)?". Can you explain?
  6. jr3151006
    Jul 30, 2010
    155
    I didn´t see registration/rejection on logs,.
    Only my firewall log registering connection attempt to our external_IP:5060...
  7. leejor
    10,362
    227
    Some people attempt a registration, from outside the local LAN using a Domain Name rather than an IP (usually when people don't have a fixed IP). If that Domain Name is not put in 3CX, the attempt will fail. I wasn't sure if that was your problem.
    Well then, I suspect that a setting in your Firewall is preventing the registration attempt from getting through to 3CX.
  8. jr3151006
    Jul 30, 2010
    155
    Leejor,
    I changed the settings on the iPhone to use IP address as the server instead use DNS name - no sucess.
    Regarding your conclusion about the firewall, if it´s true why 3CX Windows and 3CX Android works fine?
  9. leejor
    10,362
    227
    If you are able to see logs, from your firewall, then there should be some information as to why it is not passing through. You should be seeing a registration attempt in the 3CX log (even if it is being rejected). You may want to check the 3CX blacklisted IP's, maybe you made it mad and ended up on that.
  10. jr3151006
    Jul 30, 2010
    155
    Looking in the Advanced Settings, the 'IP Blacklist' is empty...
  11. jr3151006
    Jul 30, 2010
    155
    After all services running:
    Code:
    C:\Documents and Settings\Administrador>netstat -an |findstr 5060
      TCP    0.0.0.0:5060           0.0.0.0:0              LISTENING
      UDP    127.0.0.1:5060         *:*
      UDP    192.168.1.244:5060     *:*
  12. leejor
    10,362
    227
    I don't know if you've gone over this.
    http://www.3cx.com/blog/voip-howto/firewall-configuration-overview/
  13. jr3151006
    Jul 30, 2010
    155
    Just for information, take a look the response from 3CX (we are partner);
  14. leejor
    10,362
    227
    my first response to your post was...
    Which meant, it is not released/working yet.
  15. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,434
    61
    People, 3CX tunnel is only a proxy, and is available as a free standalone product and it can be used by any phone, no matter is a Grandstream, Polycom, Aastra, Counterpath, Acrobits, 3CXPhone for Windows / iPhone/Android. Install a 3CX SIP Proxy Manager on any Windows machine, configure it to the remote 3CX PBX you want then connect the mobile phone(s) to it by WiFi and that's all. 3CX SIP Proxy Manager, the tunnel, has been created long time before it appeared as embedded into 3CXPhone for Windows and during that time nobody complained they are not able to use 3CXPhone to "get out".
