V1.1.4 - Specify the host name
Discussion in 'iOS' started by sakurai, Nov 14, 2011.
  1. sakurai
    Jan 25, 2011
    11
    Device Info
    Phone Model: [iPhone]
    Generation: [4]
    Firmware Version: [5.0.1]
    Jailbreak: [NO]
    Cydia Installed: [NO]
    Issue Info
    Handset: [Phone]
    Contacts: [Local]
    Connection: [WiFi]
    Server: [Internal]
    I also have the new version has problems.
    The call can be specified with a hostname in the Local PBX IP and External PBX IP.
    If you specify an IP address can be call.
    Thank you.
    sakurai
  2. StefanW
    Jun 2, 2009
    1,199
    79
    Hello sakurai,
    i connect to my pbx only via DNS Names, also it is located in a datacenter where i change non stop the ips arround.
    So it has proven to work. i guess the issue is somewhere eals. can you run a wireshakr pcap or copy the 3CXPbx log here to see whats happens to the call. does the phone register to the pbx at all or is only calling or only getting called not working?
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,448
    61
    sakurai, please check your PM.
  4. sakurai
    Jan 25, 2011
    11
    Hi,Stefan
    Thanks for reply,here was no log of what you refer to the 3CX PBX,let's examine the cause.
    sakurai
