v1.1.4 was working; v1.1.5 won't register [Solved]
Discussion in 'iOS' started by wozzagonebush, Apr 29, 2012.
  1. wozzagonebush
    Apr 29, 2012
    Device Info
    Phone Model: [iPad]
    Generation: [2]
    Firmware Version: [5.1]
    Jailbreak: [NO]
    Cydia Installed: [NO]
    Issue Info
    Handset: [Phone]
    Contacts: [Local]
    Connection: [WiFi]
    Server: [External]
    My service provider is Internode and 3CX works fine from Windows client .
    3CX was working on both iPad and iPhone with version 1.1.4, but since upgrade to 1.1.5 I can no longer get iPad/iPhone version to register with the provider. Windows version still works OK.
  2. StefanW
    Jun 2, 2009
    1,163
    74
    Re: v1.1.4 was working; v1.1.5 won't register
    do not use external - "use as" sip account
  3. wozzagonebush
    Apr 29, 2012
    Re: v1.1.4 was working; v1.1.5 won't register [NOT Solved]
    Thank you for your response, but this did not work and is not solved :(
  4. andycww3cx
    May 15, 2012
    3CX 1.1.5 cannot working in out of office mode when using GSM network.
    in office and SIP account only working in WIFI connection mode.
    In previous version, everthing in normal working condition either in office and non office mode. I will use out of office model in GSM network when I'm not in office.
  5. StefanW
    Jun 2, 2009
    1,163
    74
    this is not correct,
    115 has only shifted Out Of Office to "Sip Account" and has now a different implementation for this profile which only works with a 3CX Phone System.
    In Office does not use STUN to resolve the external IP which will be done in Sip Account.
    More infos when what is used can be found here:
    http://www.3cx.de/blog/how-to-use-3cxphone-ios/
  6. nintendo1889
    Nov 2, 2011
    10
    Use a numeric password (no letters) on your pbx's sip extension. I had this problem registering the 3cx iphone to our PBX.
  7. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    178
    Letter Number Combo for Ext Password works just fine here.
