v1.1.5 - Tunnel not present [Solved]
Discussion in 'iOS' started by convas, Apr 30, 2012.
  1. convas
    Oct 4, 2008
    Device Info
    Phone Model: iPod
    Generation: Touch3G
    Firmware Version: 5.0.1]
    Jailbreak: NO
    Cydia Installed: NO
    Issue Info
    Handset: Phone
    Contacts: Local
    Connection: WiFi
    Server: External
    Getting "Tunnel not present" displayed on 3CX but tunnel is listed as active in the 3CX tunnel app and can make and receive calls fine.
    Seems to happen after I resume the iPod from sleep.
    11,127
    330
    Re: v1.1.5 - Tunnel not present
    It sounds as if it is being disconnected during "sleep" and needs to re-establish the tunnel connection, which it doesn't appear to, automatically.
  3. StefanW
    Jun 2, 2009
    1,222
    93
    that sounds right. with the version 1.0.0 for the tunnel we have tested apples liking of such an application and granting us to use it with background options. now we know this is okey, we will update the software soon. If you have an ipod3 then you will have no multitasking so once you put the app in the BG then it will be stopped...
