v1.1.5 Where is the "Off" Button?
Discussion in 'iOS' started by ecs, May 18, 2012.
  1. ecs
    ecs
    Jun 21, 2011
    v1.1.4 the lower righ hand button was an Off button that turned the app off. It doen't do that anymore. How do I turn off the 3cx iphone app? I don't mean minimize it with the big button on the phone, but turn it off so it isn't wastiong battery looking for connections or interuptiing me with unwanted calls in the evening.
    Phone Model: [iPhone|
    Generation: [3GS
    Firmware Version: [5]
    Jailbreak: |NO]
    Cydia Installed: [? Don't know what this is so probably no
    Issue Info
    Handset: [Phone
    Contacts: Exchange
    Connection: [WiFi|3G] both
    Server: [Internal|External] both
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    Apple no longer (since 5.x) approve iOS applications exposing an "Exit"-functionality button, therefore they asked us to be removed.
    You still can exit the 3CXphone in their agreed way, from iPhone/iPad's taskbar (put 3CXphone in the background, then double-tap device's button, showing the taskbar; find there the 3CXphone icon, hold it then "delete" it).
  3. StefanW
    Jun 2, 2009
    1,222
    93
    also try and search, the same question has been posted before:
    http://www.3cx.com/forums/can-t-unregister-on-version-1-1-5-solved-28948.html
