V1.2.11-Calling from contacts doesn't work
Discussion in 'Android' started by Pedro, Jul 3, 2011.
  1. Pedro
    Jul 3, 2011
    Device Info
    Phone Model: [HTC WildFire S]
    Firmware Version: [2.3.3]
    Issue Info
    Handset: [Phone]
    Contacts: [Local]
    Connection: [WiFi]
    Server: [External]
    When I search my contacts using the contacts button on the left side of the app I do get all my contacts,however when i choose one and dial the call doesnt go through the 3cx app but as a normal call using the cell network. Using the dial pad or receiving calls works fine.
    Thanks for any help.
    Pedro
  2. JoeDirt1954
    Aug 19, 2011
    I have a Galaxy Tab first gen. 3cx works OK, When I push the contact button my contacts show up, But you can only text them with messaging program. I believe we have the same problem, but since the Galaxy Tabs cell feature is disabled here in the US, I can only text them. I have to remember the phone number then switch back to 3cx and dial it manually. Also no speed dial feature like in the Windows version. :cry:
  3. don-coleman
    Sep 10, 2011
    V1.3.1-Calling from contacts doesn't work
    Device Info
    Phone Model: [HTC Dream]
    Firmware Version: [2.2.1]
    Issue Info
    Handset: [Phone]
    Contacts: [Google]
    Connection: [WiFi]
    Server: [Internal]
    I'm running version 1.3.1 of 3CX for Android, and have the same problem -- when I select a contact from with-in the app, it always dials via the default dialer (the cell network).
    When I type the number in manually, the 3cx recognizes the name from the contact database, and successfully makes a voip call.
    This is not a new problem.
