jr3151006 said:Hi,
when I try to dial the sound works only in the rear speaker, doesn´t matter if you change/select other option. Is this normal behavior?
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
