V1.3.4-No audio sent on second and subsequent calls
Discussion in 'Android' started by bish, Mar 14, 2012.
  1. bish
    Mar 14, 2012
    Device Info
    Phone Model: Samsung Galaxy s [GT-I9000]
    Firmware Version: 2.3.3
    Issue Info
    Handset: Phone
    Contacts: Not using them - dialling number direct
    Connection: WiFi
    Server: Internal - 3CX on LAN
    I installed 3CXphone last year when I was using an asterisk server. The problem I had was the first call works fine, but subsequent calls the audio was not sent (the called party could not hear me). I uninstalled it. Now I've moved from a linux server to a windows one, I decided to install the 3CX PABX. I've installed the 3CXphone again, but I'm having the same issue with one-way voice on subsequent calls. I auto provisioned the 3CXphone.
  2. k9protection
    May 18, 2012
    I've just cross-posted the same issue. Did you get a resolution?
