V1.3.4 - Trouble Re-registering when switching 3G to WiFi
Discussion in 'Android' started by rayfield, Nov 25, 2011.
  1. rayfield
    rayfield New Member
    May 4, 2010
    124
    Device Info
    Phone Model: Motorola Droid Razr
    Firmware Version: 2.3.5
    Issue Info
    Handset: Phone with MIC (not using Bluetooth)
    Contacts: Local
    Connection: Wifi and 3G
    Server: External (using Tunnel)
    I have 3CXPhone set to use Wifi, when available, and to use 3G/4G when Wifi is not available.
    The problem that I'm having is when I move from 3G/4G into range of an Access Point (one to which I have the phone set to connect).
    When the phone connects to the Wifi Access Point, 3CXPhone becomes 'unregistered', and won't register again until it's shut down and restarted. In fact, when this occurs, 3CXPhone locks up and has to be 'forced closed' and then re-opened, and then it will quickly re-register with the 3CX PBX Server.
    Is there a way get 3CXPhone to 'gracefully' un-register from the Server and then re-register, after Wifi connectivity?
    John Rayfield, Jr. CETma
