v10 - Cisco SPA502g - Dictionary Help
Discussion in '3CX Phone System - General' started by jr3151006, May 30, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    Hi guys,
    after read the Cisco article (http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10499/qa_c67-552213-00.pdf) I found that phone supports other languages by using Dictionary file (.xml).
    There is some place on 3CX server to create/modify .XML file and then change the language?? I´m asking because even after changing the language listbox in 'provisioning' options from extension properties, it dont change the language as I define!
    * That phone model worked fine in another language when we were using SPA9000.
    tks,
    Renato P
  2. jr3151006
    Jul 30, 2010
    155
    I´m able to update these phone using my laptop with TFTP server pointing to a folder where I downloaded .ZIP file from Cisco wich contain .XML files for languages...
    There is a way to save that .XML file inside 3CX server??
    tks,
    Renato P
