V10 Config changes don't take effect
Discussion in '3CX Phone System - General' started by amarshall, Jul 30, 2011.
  1. amarshall
    Jul 30, 2011
    Just finished initial config of V10 on an Amazon EC2 instance. I've noticed two forms of odd behavior:
    1. If I change any settings (an inbound call route rule, an extension, anything), the only way I can get those changes to actually take effect after saving them is to restart the service. After restarting the service, inbound calls don't work unless I've placed at least one outbound call.
    2. Calls aren't logged to the Server Activity log unless I do the steps in 1) as well.
    Is this expected behavior? I can't believe it is, you could never run a sizeable PBX if you had to restart the system every time you added an extension.
    I don't think this is anything to do with the fact the server is on EC2 (don't see how it could be). Any suggestions?
    Andy
  2. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    I have never seen this happen. It might have something to do with the Amazon system...
  3. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Hello Andy,
    This is not a supported method for installation, and it is not tested or recommended. I have heard of a few working in the cloud with no issues but we won't be able to give you any tips or tricks with issues that arise.
    It is not expected behavior. But you are installing in an unsupported untested environment so expect things not to work as expected or see unknown behavior.
    Nate
