v10 - DR for non business ours**FIX PROVIDED
Discussion in '3CX Phone System - General' started by jr3151006, May 1, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    I came from Linksys SPA9000 wich has the builtin option to set an audio prompt to play for incoming calls outside business hours. I cannot found similar option in 3cx...
    If there is no way to configure IT, can the DEV TEAM implement that feature in the next release?
    tks,
    Renato P
  2. StefanW
    Jun 2, 2009
    1,222
    93
    Re: v10 - DR for non business ours *** Feature request??? **
    you can do so already.
    create an DR and place ur prompt in there you like to play OOH.
    Set the Timer to 0 seconds and then terminate call as default option.
    No set up the office ours in ur System as you need them.
    After go to the DIDs you have set in ur VoIP or PSTN and remove the checkbox "same as during office hours"
    Now you see the destination leg is for IOH and OOH. For OOH choose the DR to be played. done
