v10 - Extension 105 = there's no free SLA appearance
Discussion in '3CX Phone System - General' started by jr3151006, Jun 17, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    Hi guys,
    I dont know why this is the second time that we face that problem! First was for user using '103' extension now we have the same problem for extension '103' and '105'!
    When we try to dial to these extension we listen 'transfer fail', looking at logs we found:
    Does anyone idea?
    tks,
    Renato P
  2. jr3151006
    Jul 30, 2010
    155
    I found that post: http://www.3cx.com/forums/failed-to-aquire-sla-slot-error-16333.html
    Is there any options to change at server side??? Where?
    tks,
    Renato P
  3. jr3151006
    Jul 30, 2010
    155
    I installed v10 spk1 but the problem persists!
    tks,
    Renato P
  4. jr3151006
    Jul 30, 2010
    155
    Same problem here: http://www.3cx.com/forums/call-transfer-failed-13938.html
    Renato P
  5. jr3151006
    Jul 30, 2010
    155
    Since I´m using Cisco SPA phones, I tried without success 'Enable' and 'Disable' the 'Share' as the following article:
    http://wiki.freeswitch.org/wiki/Shared_Line_Appearance
    tks,
    Renato P
  6. jr3151006
    Jul 30, 2010
    155
    I already have the parameters 'SLA_ENABLE' and 'SLA_ONSUBSCRIBE' with value '0' on my 3CX server as that article: http://www.3cx.com/forums/failed-to-acquire-sla-slot-for-dn-106-todo-do-proper-messa-20131.html#p101375
    >>> Without success = I also tried to re-provisioning the phone using URL interface (http://192.168.1.63/admin/resync?http://192.168.1.244:5000/provisioning/$MA.xml)
    tks,
    Renato P
  7. jr3151006
    Jul 30, 2010
    155
    The same problem without fix:
    http://www.3cx.com/forums/spa509g-failed-to-acquire-sla-slot-for-dn-ext-14215.html
    or
    http://translate.google.com.br/translate?hl=pt-BR&sl=de&tl=en&u=http%3A%2F%2Fwww.3cx.com%2Fforums%2Ffehlermeldung-there-s-no-free-sla-appearance-14994.html
    tks,
    Renato P
  8. jr3151006
    Jul 30, 2010
    155
    If I set the 'PHONE / LINE KEY 1 / Extension = Disable', the extension number 105 show as 'Not Registered' on 3CX web interface and I´m able to dial, obviously my call was forward to VoiceMail...
    If I set back to enable, the problem back!
    ************* So annoying....
    tks,
    Renato P
  9. jr3151006
    Jul 30, 2010
    155
    I tried 'factory reset' from the phone (Cisco SPA502g - frwm v7.4.7), without success...
    * I´m able to dial but not for receive calls.
    tks,
    Renato P
  10. Eurylink
    Eurylink New Member
    May 25, 2008
    174
    Same error and problem for me with a Cisco SPA-921 and Yealink T28 when connected over VPN. The problem is present only with v.10. With 3CX v.9 there is no problem.
  11. jr3151006
    Jul 30, 2010
    155
    The problem is related with the EXTENSION since my test was to create a new extension and provisioning to the user phone and then it works fine for dial an receive!
    tks,
    Renato P
  12. jr3151006
    Jul 30, 2010
    155
    After swapping the MAC ADDRESS from 2 phones on 'provisioning' tab and set it up to use a generic 'CISCO SPA' model instead 'SPA502g' or 'SPA922' I restated the 3CX services and then all extensions returned to work!
    * But remains the question, why it occurs!?
    Renato P
