v10 - Extension options - unable to modify!! **FIXED
Discussion in '3CX Phone System - General' started by jr3151006, Apr 21, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    After create the extension, I tried to test remotely with '3cx Phone for Windows' and I found the following error on debug window:
    Looking in to the 'Server log' I found:
    >>>>>> It´s impossible clear the flag 'Disallow use of the extension outside LAN'
    Why??? Is there a limitation? Is this a bug?
    tks,
    Renato P
    * running 'v10.0.18686.1567' on a Windows XP spk3
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Re: v10 - Extension options - unable to modify!!!!
    Did you apply the demo license key?
  3. jr3151006
    Jul 30, 2010
    155
    As I understand, the only way for the extension works remotly is using a DEMO or payed version???
    * few months ago I used the v9 wich works remotly withou problems....
    :S
  4. leejor
    10,586
    252
    Don't forget, this is still just a beta. Bugs may still be discovered by the wider audience now running it. At this point, it may be intended to be run with the Demo licence only. That might be tweaked once it is commercially released.
  5. jr3151006
    Jul 30, 2010
    155
    Re: v10 - Extension options - unable to modify!!!! ** DEMO s
    After put the DEMO key, I´m able to connect/use the extension remotely!
    Renato P
