v10 - Missed Call and Auto-dial**WORK IN PROGRESS
Discussion in '3CX Phone System - General' started by jr3151006, May 11, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    I tried a incoming call to my extension and then I see as missing call after few seconds, when I try to 'dial back' it show a message like 'Destionation Not foun' on 3cX Phone for Windows and from my SPA922 shows the msg 'Invalid number'.
    There is a way auto-replace that number using one of dial-out option (8 for use skype and 9 to use analog line through Gateway) ?? It´s anoying to use record the missed call number and then start a new dial manually...
    tks,
    Renato P
    10,855
    301
    Re: v10 - Missed Call and Auto-dial
    You would either have to prefix the incoming number with the required digit, or create outbound rules that "worked" without having to use an 8 or 9 as a prefix.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    In preferences of myphone at the bottom you have a section outbound rules. here you can create outbound rules that are loaded when you make a redial.
    Also you can right click and edit the number before dialing. Yes it is not as fast as redial but it will work. Sometimes the number will be stored with the prefix in the missed calls. We are working on this as we speak.
    So with the MyPhone you have 2 sets of outbound rules. One per MyPhone which is customized for you and another at the PBX level which is composed by the administrator.
  4. jr3151006
    Jul 30, 2010
    155
    Nick,
    I went to 'myphone' portal using my extension:
    - click on settings button
    - click on preferences tab
    - on 'Prefix' I created an entry (without success) like:
    - only input the prepend number
    - input the prepend number and numbers with 'X' length
    - input the prepend number and numbers with 'X' length and starting with 'X'
    * After each change I close my 3CX Phone for Windows (v6).
    Maybe I set in the wrong place??? Do you have ideia???
    Tks,
    Renato P
  5. nb
    nb Support Team
    Jun 7, 2007
    2,129
    153
    How does your rule look like? Also you mentioned the phone. Are you dialing from the 3CX Phone?
    The outbound rules in the MyPhone are there to be matched with
    Numbers from phonebook in MyPhone
    Numbers you dial from the dial pad
    Numbers dialed from outlook TAPI
    Numbers dialed from outlook 3CX Addin make call contact.
    Do not expect to dial a number from the 3CX Phone because that goes to the pbx directly in SIP. MyPhone gets informed from the Webserver in that case. Integration with 3CX MyPhone and 3CX Phone is one way - From 3CX MyPhone to 3CX Phone.
