v10 - MyPhone shows call to Voicemail as Answered
Discussion in '3CX Phone System - General' started by mchristsen, Jun 24, 2011.
  1. mchristsen
    Mar 30, 2010
    26
    Just upgraded to v10 and I wanted to provide feedback on something I noticed with MyPhone.
    When a call comes in and is not picked up at your extension, and is then transferred to voicemail, MyPhone shows the call as Answered instead of Missed. However the "View Missed call" icon is displayed up near the time. When you click on this, it goes to the Missed Call List, but the call is not displayed. When you change the list to display all calls, you can see the call that was missed and went to voicemail.
    I can see how it shows as answered and Voicemail picked up thte call, but I wanted to know if this is expected functionality or a bug?
    Michael.
  2. Maggers
    Mar 4, 2011
    12
    We can see a similar problem but we cant see the missed call in "All Calls" or "Missed Calls", you can see the voicemail correctly in the "Voicemail" list. Is this a bug or just an oversight ?
