v10 - Prompt set in PT-BR langague**LOCALIZATION
Discussion in '3CX Phone System - General' started by jr3151006, Apr 29, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    I´m free to cooperate with 3CX to implement PT-BR language for web administration and prompt sets also.
    What can I do for?
    tks,
    Renato P
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    171
    Re: v10 - Prompt set in PT-BR langague - what we need to do?
    Here - i had just sent the translation files of myphone. You want to start from this?
    Attached is an excel sheet. Keep it short. You cannot test your work because the resources are built at runtime so you have to translate blindly. Use acronyms when necessary if certain terms are understandable in your language.
    The first column is the identifier. This does not need to be translate - *actually dont edit column 1. Column2 are the actual texts that show up. Column 3 are comments but can be translated because they might come up in some validation screens.
    Let me know if you need any help.
    For the language prompts, send me an email - nb@3cx.com. I will guide you as to what you have to do.
  3. jr3151006
    Jul 30, 2010
    155
    I cannot found your Excell attachment, so I sent an e-mail to you!
    tks,
    Renato P
  4. nb
    nb Support Team
    Jun 7, 2007
    2,153
    171
    Excuse me - might have had an error attaching it. Here it is
    Did not receive email from you.
    I am attaching it again
