v10 - Provisioning not working?**V10-PORT CHANGE to 5000
Discussion in '3CX Phone System - General' started by jr3151006, Apr 27, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    I was trying to use provisioning by 'DHCP option 66' as the article (http://www.3cx.com/sip-phones/DHCP-option-66.html) but after restart the phones (SPA502g) I tried the 'force' option using the URL 'http://10.172.0.150/admin/resync?http://10.172.0.2:5481/provisioning/$MA.xml'. Without luck also!
    I tried to connect manually using the browser against the URL 'http://10.172.0.2:5481/provisioning/$MA.xml' and doesn´t work! I was expecting to get the xml file...
    I also tried start a 'telnet' connection to the server IP on the especified port - Without luck also!
    >>>> Why? Provisioning feature is disabled for FREE version also??? I´m wrong??
    * I´m using Abyss as webserver.
    tks,
    Renato P
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Re: v10 - Provisioning not working????
    ports for all webservers are now 5000, change 5481 to 5000 and try again.
  3. smb1
    smb1 New Member
    Mar 18, 2009
    104
    Far be it from me to question why the change of port numbers in V10 from 5481 to 5000.
    I just would hope that the voip nuggets, blog posts and configuration guides, etc are going to either be removed or updated with the new information when V10 goes "gold". Otherwise I can foresee a lot of people getting frustrated by the use of outdated information on what port to specify.
    To further complicate matters, I can foresee there being some 3CX customers who will hold off on moving to V10 until the new MyPhone matures a bit more.
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    It is already changing and getting updated however if you read the blog post about the RC it did mention port numbers changed and other information about the RC that changed or hasn't changed yet.
    "Quote from the blog post: IMPORTANT
    The provisioning port has changed to port 5000. This means that you must change the provisioning links for the phones to “http://IPADDRESSSERVER:5000/provisioning”. You can do this via DHCP option 66 or by configuring the phones from their web interface. See the configuration guides for more information. Reboot the phones after you have made this change."
    Hang in there information is already getting changed for V10 it just doesn't happen overnight.
  5. jr3151006
    Jul 30, 2010
    155
    I´m in 'doubt', in my DHCP scope must I use:
    http://192.168.1.244/provisioning
    or
    http://192.168.1.244:5000/provisioning
    or
    http://192.168.1.244:5000/provisioning/$ma.xml
  6. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    The question is WHY did the port numbers change. This is a major change that will mess people up all year.
  7. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Do exactly as you had previously done but with port 5000 instead of 5481 that is all that changed is the port number.
  8. jr3151006
    Jul 30, 2010
    155
    I ran the following command and works fine:
    http://192.168.1.62/admin/resync?http://192.168.1.244:5000/provisioning/$MA.xml
    **** Tks to everyone!!!
  9. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Yes - you must read the blog post - otherwise you will have problems.
    Well now we changed the port one final time. All websites are on 5000. Both IIS and ABYSS. No more provisioning links that are suitable for IIS and not ABYSS and viceversa
    Also we are updating the online documentation now for V10.
    For DHCP reservations you put this ip:5000/provisioning
  10. smb1
    smb1 New Member
    Mar 18, 2009
    104
    Perhaps a "sticky" post at the top of each forum category for a while after V10 is released to enhance the visibility of this change as many don't bother reading the doco, but will come to these forums for assistance.
