V10 - Ring Group - how to show the caller ID?**FIXED
Discussion in '3CX Phone System - General' started by jr3151006, May 11, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    There is a way to show the caller ID instead the Ring Group name on destiny extension????
  2. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Re: V10 - Ring Group - how to show the caller ID?
    General
    Global options
    Append group and DID names to caller ID On/OFF
    Make sure this is off.
    Like this you should get the actual caller id.
  3. jr3151006
    Jul 30, 2010
    155
    Re: V10 - Ring Group - how to show the caller ID?**SUPPORT
    >>>> You are my hero!!!
    Works like a charm! Tks!
    Renato P
