v10 - SPA400 - Call ID - how to mask it???
Discussion in '3CX Phone System - General' started by jr3151006, Sep 20, 2012.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    looking at the "Server Activity Log" we found the information bellow; since too many users face issues to get the caller ID from Linksys SPA400, there is a way to 'reconstruct' the caller ID in a way to remove/change the name of the caller?
    Take a look the attachment.
  2. jr3151006
    Jul 30, 2010
    155
    Can I accomplish that replacing some SIP Field (what?) on the 'Inbound' settings for that gateway???
  3. jr3151006
    Jul 30, 2010
    155
    My SPa400 is using the Frmwr: 1.1.2.2.
    Even trying to use the advice from "http://fonality.com/trixbox/node/38678" to set the Ports as "OFFx" (where X means the port number), It still shows as anonymous!
  4. jr3151006
    Jul 30, 2010
    155
    Probably the 'caller ID' is the biggest issue for the SPA400!
    https://supportforums.cisco.com/thread/2072869
  5. jr3151006
    Jul 30, 2010
    155
    Changing the text for "Port ID" on SPA400, just replace the text showed when receiving call, but the number still show as anonymous.
  6. jr3151006
    Jul 30, 2010
    155
    Even changing the "Caller ID/CP Tone Method" to "European FSK' stil not working
  7. jr3151006
    Jul 30, 2010
    155
    I was trying to use some advices from this post:
    https://communities.cisco.com/message/32982
  8. jr3151006
    Jul 30, 2010
    155
    After change from "ETSI DTMF" (recommended for Brazil) to "Noth American", the SPA400 cannot recognize the line signal...
    *** so obvious.
