v10 - SPA400 - Outbound calls**DEVICE CONFIG
Discussion in '3CX Phone System - General' started by jr3151006, May 1, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    I follow the article 'http://jaydien.blogspot.com/2009/09/configuring-linksys-spa400-gateway-with.html' but my 3cx web console shows as 'Not Registered' in PSTN Gateways menu...
    If I take a look in the 'Server Ativity Log' or 'Server Event Log' I cannot see anything related with that PSTN Gateway, there is a way to debug it?????
    When I go to SPA400 Status (http://192.168.1.12/html/setup.cgi?next_file=Status.htm) it shows as 'SIP registration status: Registered'. It make sense???
    tks,
    Renato P
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Re: v10 - SPA400 - Shows as 'Not registered'
    That document is too old.
    Why dont you use something more recent?
    Use the concepts here - for the spa 3102. How different can this be?
  3. jr3151006
    Jul 30, 2010
    155
    Re: v10 - SPA400 - Shows as 'Not registered'**GW CONFIGURATI
    Now it´s working fine for outbound calls but with low sound!
  4. jr3151006
    Jul 30, 2010
    155
    some pictures - part1
  5. jr3151006
    Jul 30, 2010
    155
    some pictures - part2
  6. leejor
    11,117
    329
    Re: v10 - SPA400 - Outbound calls = ok!!!!
    The only thing I have a question about is... why do you have your primary DNS server set as something (192.168.1.3) other than your gateway (192.168.1.1). You have the Google DNS server set as the second choice.
    You have a syslog server IP set at 192.168.1.3 have you looked at the logs put out by the SPA400 using something like Kiwi syslog?
  7. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    If you have low sound the only thing I see where you can play around is the GAIN.
    Make them both 0 - lets see like this.
    Then test two you can try and put them all 13 at the highest. This is a trial and error for you.
  8. jr3151006
    Jul 30, 2010
    155
    Hi Nick,
    I change the 'GAIN' field and now works fine!
    tks,
    Renato P
  9. jr3151006
    Jul 30, 2010
    155
    Re: v10 - SPA400 - Dial Out/In = ok!!!
    To receive calls, I found that advice:
    * source: http://www.3cx.com/forums/3cx-7-1-and-linksys-spa400-9880.html
    tks,
    Renato P
