v10 spk1 - "If you know your party's extension, you may..."
Discussion in '3CX Phone System - General' started by jr3151006, Jul 4, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    does anyone know if it´s possible to implement that option for incoming calls? The caller can enter the digits of the extension, like occurs on Cisco SPA9000...
    tks,
    Renato P
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Re: v10 spk1 - "If you know your party's extension, you may.
    That's a standard feature, nothing to enable, it should work during any digital receptionist prompt.
  3. jr3151006
    Jul 30, 2010
    155
    ok,
    tks. I found in the manual (http://www.3cx.com.br/manual/3CXPhoneSystemManual8_br.pdf) that it´s 'default'.
    tks,
    Renato P
