v10 spk1 - Is this an ATTACK attempt????
Discussion in '3CX Phone System - General' started by jr3151006, Jul 23, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    HI,
    I found that curious information on my logs, since the extension '100' is used only on a SIP phone (SPA 502) in our office... Is this an attack attempt??
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    if this address 188.161.246.xx is foreign (not used by you) that was a rejected attempt for registration
    this is still not an attack if not repeating (at least you need over 25 failed attempts in a short period to be considered such) - have a look on anti-hacking settings in Version 10 and search the blog / forums
    regards
  3. nbailey
    nbailey Member
    Jan 31, 2011
    359
    hey Renato,
    you have disallow extension from registering outside the local lan checked which is good, I would change the auth ID and password on this extension and keep an eye on this IP address. So no matter what they won't be able to authenticate this extension outside the lan, but do double check your settings and look into that IP address, it could be a hack attempt.
    Thanks,
    Nate
