v10 spk1 - Remote Ext show as REGISTERED even don't be
Discussion in '3CX Phone System - General' started by jr3151006, Jul 23, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    To 3CX Dev Team
    Is there an internal timer on 3CX server to check after each 'X' minutes what extensions are registered?
    I´m asking that since I used my SmartPhone (Samsung Galaxy I9000B - Android Froyo 2.2) in the last wednesday when visit the office and today looking via webinterface my extesion appears like 'REGISTERED'. Why??
  2. willow
    willow Member
    Mar 1, 2011
    471
    see if you can change the registration expiration time on the sip client. i have found that some are set to a large number and will make it look like they are registered when they are not.
  3. snowsam
    May 26, 2011
    79
    Related but unrelated, I believe I have seen extensions that showed registered (even when nothing is physically registered) when the extension is set up to forward to ring external (mobile) number.
  4. jr3151006
    Jul 30, 2010
    155
    Snowsam,
    It´s not my case! I will check the registration expiration settings.
  5. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Try reducing the MAXEXPIRATION parameter to 300 seconds:
    http://www.3cx.com/blog/docs/3cx-phone-system-parameters-table/
    This will increase the traffic load to 3CX but will provide more accurate information about the registration status of the remote phone. Try also reducing the registration period on the phone itself (in most phones the default is 3600 seconds).
    The other useful parameter is SIPPINGPERIOD. Try setting it to something like 60 seconds. This will also help learning the actual status of an extension.
    Regards
